It is currently Sun Jul 20, 2025 5:56 pm
PostPosted: Tue Aug 14, 2007 11:46 am
I have used this for quite some time, but as I was using it today I thought about the forum and thought I would share this jig I use.
It will help you when you are mounting your neck so that you can be assured that it is in line and centered on the guitar... even a tiny bit off of center will show up dramatically. It also will place your bridge in the perfect location every time with no measuring. It ends all of that fussing with straight edges and rulers and wondering if your bridge is located in the perfect spot.
This jig slips over your fretboard and has ears on each side to hold it in the perfect centered position. The top portion of the jig was made by cutting the plexiglass to the same dimensions as my normal fingerboard size and then 4 "ears" were super glued on to hold it in the exact position. Notice that there is a scribed line down the center on the lower portion. This will tell you whether or not your neck is centered while you are sanding it into position.
At the lower end of the jig, there is a saddle glued to it. I made this jig by using a Martin D35 guitar that I knew was in perfect condition for the scale and intonation. By butting the neck end of the jig up against the nut and sliding the glued on saddle into a saddle slot on your new bridge, it will locate the bridge for you and you can be assured that it is in the perfect spot for a 25.34 Martin Scale. no measuring needed and guaranteed to be centered also
This was all made out of scrap lexan I had laying around the shop. That is why you see the "extra" piece of lexan scarfed onto the end of the jig in the last picture. When Imade this jig, I hand sanded the saddle end of the jig until it just would drop into position while the nut end was firmly pressed against the nut of the known good guitar.  WHen it just would drop into position, I super glued it in place using an excellerator to keep it from gluing itself to the saddle of that guitar. This is how I am so sure that this works and is perfect intonation.
Of course if you use this jig, you would need to make a different jig for every nut width you use and also for each scale. All of the guitars I have made so far all use 25.34 scale, so the one jig does it all for me. My next model will have some self-centering adjustable ears on it so that different fingerboard widths can be used with the same jig. I may get really inventive and also have an adjustable scale length as well. for now, this is all I need.
Hope this helps!
PostPosted: Tue Aug 14, 2007 12:26 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Wow Ken I really like that.It seems it would be pretty easy to adapt what you`ve done to something adjustable.Especially the length for different scales.I hope you don`t mind if I make myself one.I really like the idea that it centers the bridge at the same time it finds the scale location.This should definately go on the tutorial page.
                      Thanks James
And also you know the other day when you had problems with sandpaper gumming up on your Performax.The other day when I was sanding some sides ,I just took a fan And opened the door on the sander and blew it directly on the roller where it contacted the wood.Of course I was outside ,but it worked pretty good,and is a lot cheaper than an expensive dust collection system.Sorry to change the subject ,just thought it might help.
James W Bolan
Nashville Tennessee
PostPosted: Wed Aug 15, 2007 7:21 am
I just got one of Tracy's jigs as well I love it. I plan to adapt it to have a pseudo saddle in place on the bridge locating proton so all I do is stick the bridge on the pseudo saddle and move to the predefined location points according to scale length and mark my bridge location. Great fixture both for neck alignment and bridge location
PostPosted: Wed Aug 15, 2007 8:54 am
Great work Ken,
Thanks for the tip, very useful, straight forward, practical and CHEAP!
PostPosted: Wed Aug 15, 2007 9:30 am
First name: Tracy
Last Name: Leveque
State: CO
Great jig Ken, and thanks for sharing. A very useful jig that others can make easily. For all others that are enjoying my CenterLine Finder jig, thanks for the kind words!
PostPosted: Wed Aug 15, 2007 9:57 am
Another plug for Tracy's jig. I'm a rank beginner, but used it to find where the bridge went. My guitar-building buddy then used his conventional methods to check to see if I was right. Spot on!
It's so easy, even a ca...ah, nevermind.
PostPosted: Thu Aug 16, 2007 12:58 am
I make one almost identical to Ken's. I don't bother with the side extensions and just use centering marks. That is very easy to get right by eye. I do use the faux saddle to orient the bridge. I make one for every scale length and that takes about 1/2 hour or less. I don't like the adjustable kind because anything that can be adjusted has to be adjusted and can be out of adjustment.
